Polygons not covered with lines
  • July 14, 2014
  • 5 replies
  • 42 views
i have two shapes, polygon and lines. How to find polygons that is not completely covered with lines? Tnx
  • July 14, 2014
If you need to find polygons which never overlap any line, apply the LineOnAreaOverlayer, and look at overlap count attribute (named "_overlaps" by default) of the output Areas.
Takashi
  • July 14, 2014
no, for example, i have one polygon and five lines that form the polygon. For example, one of these five lines are missing and i need that polygon in result.
  • July 14, 2014
OK. How about this approach?
Send the lines to the LineJoiner --> GeometryCoercer (Geometry Type: fme_polygon).
If the lines forms a polygon, output will be a polygon. If not, output is still a line.
Then, select output lines (GeometryFilter), and compare them with the polygons to select required polygons (SpatialFilter etc.).
  • July 14, 2014
Alternatively, the AreaBuilder could be used instead of the LineJoiner and GeometryCoercer.
gio
Forum|alt.badge.img+15
  • July 14, 2014
GeometryCoercer on the polygon and than SpatialRelator between inputlines and the coerced lines from the polygon.
If topology is the same you can use "Equal".
If it is not, "INTERSECT". Calclate cardinality and test for relationships{}.card.line>0
Tis will eliminate the bare line.
