pointcloud and georeferencing
  • May 20, 2023 8:42 AM UTC
  • 39 views
4ntoines
Hello,
I have a point cloud and I would like to get a buffer around each point (to apply an intersection with another mesh)
I have placed the following transformers: PointCloudToPointCoercer to separate each point (output geometry: individual points) and then a buffer (buffer type: solid)
The workbench works fine, only in the operation, somehow, I lose the georeferencing
Does anyone have a solution?
ThanksFME
itsmatt
Forum|alt.badge.img+48
  • May 22, 2023 12:59 PM UTC
What is your output format? Depending on the output format the coordinate system may indeed get lost.
