Point measures based on attribute value
  • Jul 25, 2021 2:11 PM UTC
  • 93 views
ireen
Forum|alt.badge.img+5
I have a line and a point dataset. The lines have measures, generated with the MeasureGenerator. Some lines are partly overlapping, so they share part of their route. The lines have a "ROUTENAME" and the points have the same attribute, indicating which line they are associated to. Now I want to derive the measure value of the points along the route, but only on the route they are associated to.
How can I make the PointOnLineOverlayer and MeasureExtractor take into account the "ROUTENAME". Now some points get the wrong measure (of another route on the same location).
Any ideas to help me out?
Best answer by hkingsbury
In the PointOnLine, set the GroupBy value to "ROUTENAME". This will then only compare features that have the same value in that attribute
hkingsbury
Forum|alt.badge.img+73
  • Jul 25, 2021 7:52 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Jul 25, 2021 9:57 PM UTC
Nice answer
ireen
  • Jul 26, 2021 12:58 PM UTC
Indeed. I had tried this before, but it seems that other data-issues made that it didn't lead to the expected result. It is solved now.
