Output sorted features as PNG
  • Oct 25, 2023 12:13 AM UTC
  • 41 views
jp12212
Forum|alt.badge.img+4
I have a sorted list and want to output as a PNG, which transformer should I use?
I couldn't go direct from a sorter to a PNG Writer?
  • Oct 25, 2023 5:36 AM UTC
Hi @jp12212​ ,
What are described in the "sorted list"? PNG filenames or somthing else?
jp12212
  • Oct 25, 2023 5:50 AM UTC
It's strings and another column of numbers. Just want to save that sorted list into a PNG.
Not sure if that's possible with styling etc. or as a table?
Was looking for something similar to the HTML generator but that would just print the features as bullet points or 1,2,3 etc.
  • Oct 25, 2023 6:12 AM UTC
PNG is an image data format, I cannot imagine how you want to transform the strings and numbers to an image.
Can you please share the list and explain what is your expected image a bit more specifically?
nielsgerrits
Forum|alt.badge.img+67
I do not know why you want it, but you can always explode the list to features (ListExploder) create points (VertexCreator) create labels (LabelPointReplacer) rasterize vector to raster (ImageRasterizer) and write the png (FeatureWriter).
