Offsetcurvegenerator reverses line orientation?
  • Sep 5, 2014 8:50 AM UTC
  • 36 views
ngoorman
Forum|alt.badge.img+3
in my workbench I use Offsetcurvegenerators. I've noticed that the output line has a reverse orientation compared to the input line. Now that I know this, I can easily adapt my workbench to it, but I find counterintuitive. It also makes it harder to use a second Offsetcurvegenerator, since left is suddenly right, and right is left.
Is this intended behavior? If so, I would recommend documenting this in the transformer's help text.
  • Sep 6, 2014 8:10 AM UTC
The Right lines output from the transformer indeed were reversed. I guess such result is related to the history of the OffsetCurveGenerator, which has been derived from the Bufferer.
I agree that it's better to be documented.
