NetCDF writer: Failed to end definition. The error was 'NetCDF: One or more variable sizes violate format constraints'
  • Jun 7, 2022 12:45 AM UTC
  • 8 replies
  • 388 views
nicholas
Forum|alt.badge.img+14
I want to mosaick 188 netCDF files into a single netCDF file. I get the error
The data is a DEM, so only one band which is elevation.
I have attempted both "Classic" and "64-bit Offset" Parameter
What am I doing wrong?
  • Jun 7, 2022 6:59 AM UTC
Difficult to say without more details. Perhaps you can post some sample data here?
NetCDF is a fairly tricky format, you'll probably have to make sure that the contents of the various lists like "netcdf_band{}.coordinate_variable{}" matches the number of bands in the output file.
nicholas
  • Jun 8, 2022 5:41 AM UTC
The netCDF files are really large, so I don't know if it would be possible to post sample data.
Only one band, representing elevation, in metres (decimal metres)
X and Y is Longitude and Latitude in decimal degrees
70314 rows
57924 columns
nicholas
  • Jul 14, 2022 11:54 PM UTC
Attached is one (zipped) csv. There are 187 more like this
nicholas
  • Jul 14, 2022 11:55 PM UTC
Attached here is the netCDF that I generated from the csv I attached just before
nicholas
  • Jul 15, 2022 2:40 AM UTC
@david_r​ I have uploaded some data, as you suggested
nicholas
  • Jul 15, 2022 2:50 AM UTC
And here are my workbenches. The Runner & Worker convert all the csv files into netcdf files. This succeeded.
Then I tried to mosaic all of the netcdf files into a single netcdf file. This failed.
  • Jul 15, 2022 6:33 AM UTC
I just did a quick test with the NetCDF file that you posted, I had no issue mosaicking several versions of it. I you can't find the solution, I recommend you contact your FME reseller for assistance.
nicholas
  • Jul 15, 2022 6:36 AM UTC
I do succeed in mosaicing about a dozen netcdf files together. I get an error when I attempt to mosaic all 188
