neighborfinder does not supoorted the default selection is touch maximun length edge
  • Dec 23, 2021 5:12 AM UTC
  • 39 views
for an example:
why is the result not is 1 but 4
sample
Forum|alt.badge.img+63
The NeighborFinder does not consider lengths of touching edges, if there's more than 1 match (in this case 1, 3 and 4 would all have a distance of 0 as they touch) it'll pick the first one it comes across as being the closest neighbor.
You may want to look into the SpatialFilter and Intersector if you want to pick the one with the longest joint edge as the closest match
okey​
