Move Floor plans side by side
  • September 20, 2017
  • 73 views
venu
Forum|alt.badge.img+5
Dear All,
I have multistory building plans and each floor located the same place.
I need to move each floors side by side.
for example, 15 floors need to move side to side as like 5 (Column) X 3 (Row)
Please advice to achieve this task
Thanks in advance.
Venu
Forum|alt.badge.img+54
The offsetter is probably what you need here, using the floor number to determine the offset
venu
thanks, can suggest how can place row by column
I would use something like the following to determine row and column position for each floor then use these to determine the amount of offset needed
offset-to-grid.fmw
