Move all data to zero
  • Apr 17, 2023 10:21 PM UTC
  • 6 replies
  • 71 views
jp12212
Forum|alt.badge.img+4
I'm new to FME and want to create a workbench that translates 3D data to zero.
I have IN (reader) -> CenterPointExtractor -> Affiner -> OUT (writer).
Within Affiner have:
1, 0, @mult(@Value(_inside_x),(-1))
0, 1, @mult(@Value(_inside_y),(-1))
I've tried a bunch of variants of this but am struggling to get the data to move to zero. Workbench attached.
Thanks for the assistance.
daveatsafe
Forum|alt.badge.img+24
  • Apr 17, 2023 10:43 PM UTC
Hi @jp12212​,
The Offsetter might be simpler than the Affiner, since you can just us the negatives of the center values as your offsets.
jp12212
  • Apr 18, 2023 1:24 AM UTC
Hi @daveatsafe​ ,
I have modified as per below but it seems to not be working still. Any suggestions.
Cheers
  • Apr 18, 2023 7:47 AM UTC
You'll still need to offset relative to the geometry reference point (in this case it's the center point), otherwise you'll just move the geometry 1 ground unit south-west relative to the original position.
Try this:
jp12212
  • Apr 18, 2023 10:48 PM UTC
Try this:
Hi David,
Thanks for getting back to me - this seem to be working but not all the elements are moving (only the lines, not the solid box). Is this behaving as it should? I will go and test a couple of other files in case. If you see anything incorrect here though please let me know.
daveatsafe
  • Apr 18, 2023 10:57 PM UTC
Hi David,
Remove the connection between the source feature type and the Offsetter - it is bypassing the CenterPointExtractor, creating a second set of features at the original location.
jp12212
  • Apr 18, 2023 11:04 PM UTC
Great, thank you!
