Missing z-value when writing GIS data to DWG
  • Oct 4, 2022 12:45 PM UTC
  • 154 views
I am reading some data from a ESRI based web GIS and need to convert them to DWG. The data contains XYZ data, but the Z-values are missing when opening the DWG in CAD-software.
I got Z-values before writing:
This is my workspace:
AutoCAD:
How can I make sure the file contains Z values?
dustin
Forum|alt.badge.img+36
  • Oct 4, 2022 1:00 PM UTC
Are your Z values being passed through each of your transformers. In other words, if you inspect the features coming out of the Reprojector, are your Z values still present?
  • Oct 5, 2022 1:23 PM UTC
I solved the problem by moving the DWGStyler before SurfaceDraper. It looks like the DWGStyler forced the feature to be 2D some how.
