Merge or filter points that have a common attribute value and are spatially close
  • Sep 11, 2017 2:20 PM UTC
  • 75 views
pimververgmail
I have a couple of thousand points that have a number as attribute. Some of those points are
- close to each other - also have the same number Note: there are also points that have the same number but are far apart. I want to merge all points that match both conditions into 1 point So far I have set a neighbourfinder transformer, which groups the points by number and then finds the closest points (max 4). But how do I merge the resulting related points into 1?Any suggestions are welcome. Kind regards,Pim Verver
erik_jan
Forum|alt.badge.img+26
  • Sep 11, 2017 2:31 PM UTC
Have a look at the NeighborhoodAggregator and the use the CenterpointReplacer to replace the aggregate by 1 point in the center.
  • Sep 11, 2017 2:43 PM UTC
Agree. Most importantly, use your common identifier as the Group By in the NeigborhoodAggreator (or NeighborFinder, if you prefer).
