merge date columns
  • Jan 8, 2015 8:46 AM UTC
  • 44 views
Hi all,
I am reading a number of records from an Oracle database. When using FeatureMerger on these, I find that the resulting features have NULL values for attributes DATE1, DATE2, etc., while the attributes DATE1.full, DATE2.full have been merged correctly. Is there a simpler solution than exposing the DATEn.full attributes and converting them to the DATEn attributes? (There are a LOT of such date attributes.)
Any help greatly appreciated.
Regards,
Steinar
  • Jan 8, 2015 11:15 AM UTC
the easiest is probably to use a BulkAttributeRenamer:
this will rename e.g. DATE1.full to DATE1, while preserving the value from DATE1.full.
David
  • Jan 8, 2015 11:17 AM UTC
Btw, you do not have to expose any attributes for this to work. Just add the BulkAttributeRemover right after the reader and you should be all set.
David
  • Jan 8, 2015 12:50 PM UTC
Thanks David,
It seems that FeatureMerger (for some strange reason) refuses to merge other date attributes than the original .full ones, so I need to place the BulkAttributeRenamer after FeatureMerger, and then reformat the attributes from the YYYYMMDDHHMMSS format to the YYYYMMDD format I require. I suppose DateFormatter should do the trick.You are right in that I do not have to expose the attributes - learned something new today.
Steinar
