Max pixel with percent clip
  • Nov 9, 2017 3:55 PM UTC
  • 0 replies
  • 33 views
jdh
Forum|alt.badge.img+41
Thoughts on the most efficient way to get a single raster with the max value from 50+ rasters with the caveat that the top 10% for each pixel need to be discarded.
ex. if a pixel had the following values [0,7,3,7,2,6,8,2,3,1] then the result would be 7.
If it has [4,6,8,2,4,9,5,4,9,2] it would be 9.
Because of the percent clip, I cannot simply use a RasterMosaicker with Overlapping Values set to Max.
The inputs are over 10GB of data, so I would prefer not to coerce to individual points if possible.
