Matcher and match_id further selection
  • Mar 21, 2018 10:42 PM UTC
  • 79 views
Hi all,
I have used Matcher to find duplicates. It works very well. I create "_match_id" attribute to create "small groups".
The problem is there, I need now to sort into these "small groups" using an other attribute called "Hierarchy" (numeric attribute). The feature with bigger Hierarchy's attribute value into this small group (based on _match_id value) will have a red color, the other will have a blue color.
So, I have to compare each value into this small group, keep the highest value and assign to this feature red color.
I have to do this for every small groups.
Any ideas ?
Thanks
Best answer by takashi
Hi @arka, if I understand the requirement correctly, this workflow might help you.
  1. Sorter: Sort the Matched features by "Hierarchy", numeric descending.
  2. Sampler (Group By: _match_id, Sampling Rate (N): 1, Sampling Type: First N Features): Sample the first (i.e. highest Hierarchy) feature for each group.
  3. FeatureColorSetter x 2: Set red color to the features output from the Sampled port, set blue color to the features output from the NotSampled port of the Sampler above.
fmelizard
Forum|alt.badge.img+22
  • Mar 21, 2018 10:57 PM UTC
Hi @arka, do you have any example data that you can share? Screenshots can be super useful.
  • Mar 22, 2018 1:30 AM UTC
  • Mar 22, 2018 1:33 PM UTC
Hi @takashi. Thank you for your supply, it works very well.
