Mapping files together
  • Oct 29, 2019 7:01 PM UTC
  • 48 views
Hi I have two ESRI geodtabase files with different parcel information for same location. I am interested in joining the two records based on the corresponding same location. The attributes for the file looks as follows:
I want to get a table that contains all these attributes together, for a same location?
Is it possible.. Any help will be appreciated.
  • Oct 29, 2019 7:16 PM UTC
I want the final file to have all these attribute together
danilo_fme
Forum|alt.badge.img+58
  • Oct 29, 2019 7:25 PM UTC
Hi @vakansha
I suggest you to use transformers for SpatialRelator's: SpatialFilter, SpatialRelator and get all attributes that are on the same location.
Thanks in Advance,
Danilo
