Make a Raster's "value" decrease from the center of the raster to it's short side
  • Feb 5, 2018 3:35 PM UTC
  • 119 views
Currently my workbench creates a polygon that I convert to a Raster with a cumulative oil number as the Z Value.
Now, what I want to do with this Raster is:
From the middle of the Raster to the short side of the polygon (see attached jpg) I want to slowly decrease the pixel value from 100% to 0%.
How can I accomplish this in FME 2017?
jdh
Forum|alt.badge.img+41
  • Feb 5, 2018 3:50 PM UTC
I would probably create an alpha band with the appropriate decay and add in to the raster with the value, and then mosaic it with an all 0 raster (alpha 255) with composite using alpha channel.
The 0 raster should be first into the mosaicker.
See https://knowledge.safe.com/articles/1219/alpha-compositing-blending-two-raster-images.html
  • Feb 6, 2018 1:30 PM UTC
Hi @jeffm, if I understand the requirement correctly, this workflow might be a solution. Assuming the input geometries are 3D polygons that forms a roof-like shape. The range of resulting cell values will be 0 - $(MAX_VALUE).
Left: Input (3D Polygons), Right: Output (Numeric Raster)
  • Feb 6, 2018 8:52 PM UTC
I just have the one polygon, it isn't folded. The line in the middle of the graph is what is used to make the buffer. It's just a polygon with a value. It sounds like I need to break down the polygon into raster cells, then somehow calculate the cell values depending on it's spatial position.
jdh
  • Feb 6, 2018 9:02 PM UTC
If you look at the alphaCompositing workspace in the above link, there is a MultiBufferer custom transformer, that creates buffer rings, and an ExpressionEvaluator that creates a decay value based on the buffer id and number of buffers.
Use that on your line. I tend to use 20 buffers with a 5% drop in value, but that is completely customisable.
