Make a parallel buffer
  • Apr 17, 2018 8:51 AM UTC
  • 61 views
geo-x
Hi everybody.
I try to make a buffer only with parallel of line, because the transformer bufferer make a complete buffer with start/end line vertex.
So I try this
but I've a problem with the AreaBuilder who doesn't make area...
Do you think this is a good method ?
  • Apr 17, 2018 9:13 AM UTC
Hi @lalandexavier, the AreaBuilder requires that input lines properly connected at thier end nodes. Try inserting the Intersector between the LineExtender and the AreaBuilder.
By the way, why not use the Bufferer (End Cap Style: None)?
geo-x
  • Apr 17, 2018 9:29 AM UTC
Dear Magic @takashi , this is a perfect way, thank you very much !
For the bufferer, I would like to do with this transformer but I don't find this option
  • Apr 17, 2018 9:41 AM UTC
The 'None' option for the 'End Cap Style' parameter should exist in the Bufferer. If the option is missing in the localized FME (French?), please contact the localizer.
