ListSearcher - multiple attributes
  • March 21, 2014
  • 100 views
Hi all,
Wondering why ListSearcher does not support this, I'm looking for a clever way to find the first exact match on several attributes in a list. Do I have to delve into Python programming, or is there an easier way?
Thanks in advance,
Steinar
  • March 21, 2014
Hi Steinar,
Although scripting could be a workaround of course, I think that the ListExploder and the Tester can be also used.
Takashi
  • March 21, 2014
Takashi,
Yes, of course. Silly me.
Thank you so much!
Steinar (Rookie)
  • March 21, 2014
just be aware that if you have huge datasets, the ListExploder has a tendency to also explode your memory consumption... Consider using a scripts if this is the case.
If not, I agree that the ListExploder / Tester combo is the easiest.
David
