LineOnAreaOverlayer - one area against all lines
  • Jan 24, 2022 9:09 AM UTC
  • 57 views
bjoern
is it possible to use the LineOnAreaOverlayer transformer to test all lines in an area against all areas step by step. That means i have 10000 areas and all should be testest one by one against the 15000 lines in the line port. As a result I need a list which shows me what lines are in every single area. And yes, the same line will be in more than one area. Maybe i colud use a second workspace and use the workspacerunner to bring the data in, but i hope there will be a smarter solution for that.
Best answer by redgeographics
Yes, this should be doable in the LineOnAreaOverlayer, you can have it generate lists on the output ports. I don't think a second workspace will be necessary in this case.
You can also consider using the SpatialRelator for this, it might be faster.
Forum|alt.badge.img+63
bjoern
  • Jan 24, 2022 11:18 AM UTC
Thank you the list-option did the job. For some reason I forgot to check this.
