“line string or poly boundary is self-intersecting” error,
jamal
Forum|alt.badge.img+5
On our workflow, the CAD hatches that represent the Landuse are converted to polygons and then these polygons are collected in one layer stored in ESRI enterprise geodatabase.
As the FME is applied to convert the hatches of CAD to GIS polygons, these generated polygons by the FME introduce error as they are copied and pasted to the destination layer in the enterprise geodatabase.
CAD file:
http://www.mediafire.com/download/x7plx8ka56kg9ai/AsSamou_Hebron_MasterPlan_05_X_02.dwg
The workbench is:
Error in ArcGIS (as the layer is copied and pasted)
Which command should be included in the workbench to avoid such error?
Thank you
Best
Jamal
Best answer by takashi
I guess the reason is existence of very narrow parts of the donut polygon. The GeometryValidator seems not to be able to repair it perfectly.
In such a case, my last resort is to use the Bufferer to shrink the boundary a slight.
  • April 18, 2014
the GeometryValidator has an option to fix 2D self-intersects. Be sure to do it just before the output, so you don't snap or clip the geometries after the repair.
David
jamal
  • April 20, 2014
Unfortunately, checking the “self-intersections” in 2D doesn’t solve the issue
The Landuse polygons
The Boundary polygon
The Roads polygon (Roads = Boundary – Landuse)
The combination of Roads and Landuse (Roads + Landuse)
The error as the Roads and Landuse are copied and pasted to the DESTINATION enterprise Geodatabase layer
jamal
  • April 20, 2014
Cont.
What other solutions might still be there?
FME Workbench:
http://www.mediafire.com/view/vnv1ex43575uha1/UrbanMasterPlan_CAD_To_GIS_15.fmw
Excel file for mapping:
http://www.mediafire.com/view/m9j7828verq26nk/UrbanMasterPlanDomain_FME_18.xls
  • April 20, 2014
Hi Jamal, have you tried "Check Self-Touching Polygon" parameter?
Takashi
jamal
  • April 20, 2014
Thanks Takashi,
I tried it and I got the error below
I thank that the error now is with the Roads layer that it derived from the Boundary and Landuse layers
Roads = Boundary – Landuses
I tried to copy and paste the Roads layer (only) and I got the same error.
How to fix these very frustrating errors?
  • April 20, 2014
jamal
  • April 21, 2014
Thank you very much Takashi.
It appears that “bufferer” has resolved my issue. It works like a charm
Best
Jamal
