Line Orientation extractor
  • Apr 20, 2017 12:42 PM UTC
  • 543 views
bubblebeb
I am trying to extract the orientation / angle / direction of a 2 node line.
I cant believe there isn't a transformer that simply extracts the orientation of a line but I cant find one.
Anyone found one?
I want to be able to compare the orientation between two lines which are close to each other to determine if they are in the same (or similar) orentiation.
Thanks
  • Apr 20, 2017 12:51 PM UTC
Have you looked at the AzimuthCalculator on the FME Hub?
bubblebeb
  • Apr 20, 2017 12:56 PM UTC
Easy as that. Many thanks @david_r
anamanvil
  • Jun 28, 2021 10:28 AM UTC
Is AzimuthCalculator no longer available on FME Hub?
  • Jun 28, 2021 10:46 AM UTC
Somewhere along the way the name was changed, it's now called the HorizontalAngleCalculator.
