LengthToPointCalculator - many points on one track
  • Dec 20, 2017 3:18 PM UTC
  • 109 views
I have one track stored in MID/MIF, and a couple of points from other source. It is something like bus route with list of stops. All what I need is to know, how far from the very first stop each other bus stop is. Looks like it is a task for a LengthToPointCalculator, but I can not achieve right way how to use it.:( From what I am starting: I use two MID/MIF readers as sources - one for route, another for stops. Then I use CoordinateExtractor to get X and Y as attributes for each point. And after some alchemy we reach that LengthToPointCalc. I do not want to explain all variants I've tried, but in any case I got only zero as lengths. There are no problem to get length between every pair of sequential bus stops. But I can not imagine how to sum it after that. I will appreciate any help!
Best answer by ebygomm
If you add the line geometry to each feature that contains the x,y attributes the length to point calculator should give you the output you require
Forum|alt.badge.img+54
  • Dec 20, 2017 3:38 PM UTC
  • Dec 20, 2017 3:57 PM UTC
@egomm thank you alot! I got it. And thanks for join on 1 1:) Was trying to get it throw Cloner, but something was wrong with points counter. With your key all is just fine!
