LengthToPointCalculator in 3D issue
  • Jan 20, 2020 6:30 PM UTC
  • 54 views
I am trying to use the LengthToPointCalculator in 3D mode however whenever I run my workflow I get the following warning message:
WARN |@Length -- Cannot calculate length to a point in 3D. Continuing using 2D
The line geometry is definitely 3D as I can see the elevations for each vertex in the Inspector. Has anyone else experienced this and if so, do they have a solution?
I am using FME Desktop 2019.1
Thanks,
fmelizard
Forum|alt.badge.img+22
  • Jan 22, 2020 10:34 PM UTC
Hi @aquamarine I haven't seen that error for a very long time. Please send us details of the problem via https://www.safe.com/support/report-a-problem/ Thanks!
  • Jan 29, 2020 2:25 PM UTC
Thanks @danatsafe I have just submitted this and case number is C151590
