Last two records in a column
Hello all!
This seems like it should be a very simple thing to do but I am drawing a blank. I have an attribute column full of numbers (Dates). I just need to sort it and get the latest two records and put them under separate attributes. This is what the column looks like (already sorted descending).
I need to assign "170503" to one attribute (let's call it "DATE")
I need to assign "170331" to "previous_DATE"
Any help will be appreciated. Thanks!
danilo_fme
Forum|alt.badge.img+57
Hi @fariyafarhad
I created a template file in 2017 and extract these informations using Counter, StatisticCalculator and TestFilter.
Please, see this template :)
Danilo
workspace-filter.fmwt
I managed to find the solution myself:
Hi @fariyafarhad
Danilo
Hi @danilo_inovacao thank you for your answer. I managed to find the solution right after I posted the question. Yours works pretty well too!
danilo_fme
:) Good!
