KML XQUERY RESULT ATTRIBUTES
  • June 18, 2013
  • 56 views
tbs_gis_team
Forum|alt.badge.img+3
I used a process on here to convert a KML file through the HTMLto XHTML Converter then through XQuery Extractor and that seemed to split out the KML description into the result attribute when I run it through and inspection point. I am trying to convert the KML to a SDF or shapefile to import into my GIS system, but I cannot get the result attributes to append to the writer file. I have tried a list indexer and multiple other transformers with no luck. Any help would be greatly appreciated.
Thanks,
Chad
Best answer by tbs_gis_team
Figured it out, attribute exposer is what I needed. I just downloaded 2013 SP2 and FME added that option in the transformer.
Chad
tbs_gis_team
  • June 18, 2013
Chad
