Joining housenumbers ot number intervals
  • Dec 19, 2017 10:40 AM UTC
  • 5 replies
  • 80 views
Hi all
I have an interesting task of joining 2 datasets:
One dataset is a table with house numbers, the table has roadids, housenumbers (including letters) and an attribute that shows if the house number is an even number og uneven.
The second datasat contains roadids that matches the first dataset but instead of specific house numbers the second dataset contains 2 attributes: house_number_from and house_number_to, the second dataset also has an attribute telling if the intervals are even or uneven numbers.The second dataset also has a district_id attribute.
I have to join these datasets to get the district_id joined on the first dataset. I somehow have to determine if the adresses in the first datasets fall between the intervals in the second grouped by the roadid
I have attached both datasets here:
does anyone have an idae how to go about this?
Best answer by takashi
Hi @oaralb, if I understood the requirement correctly, the InlineQuerier with this SQL statement could generate desired result. merge-district-to-houses.fmwt (FME 2017.0.1.1)
select    a.*,    b.house_number_from,    b.house_number_to,    b.district_idfrom house_numbers as aleft outer join district_intervals as bon b.roadid = a.roadid and b.evenuneven = a.evenunevenand (a.house_number_int between b.house_number_from_int and b.house_number_to_int)
  • Dec 19, 2017 11:54 AM UTC
  1. It seems that some house numbers contain alphabetic characters. How you can determine large and small between two house numbers if one of them or both contains an alphabetic character?
  2. Are '001' and '1' an identical number?
  • Dec 19, 2017 12:53 PM UTC
Hi
Yes, the letters are a problem but I think the end result will be ok if we remove the letters so i have added 2 new datasets to this post with the letters and numbers ind seperate columns. I have also trimmed down the leading zeroes (which i should have done in the first place.)
the columns containing house numbers without letters have _int in the column names.
district-intervals.xlsxhouse-numbers.xlsx
  • Dec 19, 2017 1:49 PM UTC
  • Dec 20, 2017 12:22 PM UTC
Awesome, that did the trick :)
  • Dec 20, 2017 1:21 PM UTC
Good to hear that. In addition, some string operations might be helpful to extract integer part from the number attribute. e.g.
Hope this helps. Happy holidays!
