Join table after clipping
  • November 24, 2016
  • 81 views
simonhume
Forum|alt.badge.img+7
Hi
I've set up a workspace to extract certain types of businesses (a MapInfo point dataset that I have a tester attached to to extract the types) that lie within an employment area (a MapInfo polygon table).
Using the Clipper function, this workspace runs fine and i get a result output into a MapInfo table.
The output table includes all the attributes from the point dataset, but i want to also include the attributes from the Employment Areas dataset (only 2 columns, but they're both useful) attached to each record in the output table.'
I have tried many of the Feature, Attribute and Spatial functions, but cannot get the 2 tables to be merged into one after the Clipper has extracted the data.
Apologies in advance if this isn't explained very clearly. Am a new user of FME so am still on a steep learning curve to understand what to do when when setting up a Workspace! Hopefully someone can answer my query
thanks
Simon Hume
Forum|alt.badge.img+63
You can try the PointOnAreaOverlayer to do an overlay, although the Merge Attributes parameter in the Clipper transformer should be able to do this as well.
  • November 24, 2016
Hi @simonhume, try checking the "Merge Attributes" checkbox in the Clipper parameters dialog.
itay
Forum|alt.badge.img+19
  • November 24, 2016
Next to what @takashi mentions, beware of possible attribute conflicts between the 2 feature types (point and polygons) and use the accumulation mode and conflict resolution accordingly.
Hope this too helps
simonhume
  • November 29, 2016
Good morning all
Apologies for the delay in replying, but your suggestions have worked and i now have the workspace running as i require
Thanks to all for their replies
regards
Simon Hume
