Join poorly drafted lines
  • Dec 7, 2017 7:19 PM UTC
  • 67 views
sunhenry617
I hope someone can help me out. I have some curb lines that are poorly drafted. I tried to use Snapper (with various snapping tolerance ranging from 0.1 to 5) and then LineJoiner to join them together, but had no luck so far. I attached the file here so if you want to give it a try, please go ahead.
Thanks in advance.
Best answer by ebygomm
Try discarding any lines smaller than your tolerance before snapping and joining, this workflow produces a single line from your input file
Forum|alt.badge.img+54
  • Dec 7, 2017 8:36 PM UTC
sunhenry617
  • Dec 7, 2017 11:26 PM UTC
Thanks a lot, @egomm. I will give it a try shortly. If that works, you have saved my day!
sunhenry617
  • Dec 8, 2017 3:47 AM UTC
Hi @egomm, I just tried your method and it works perfectly. Thank you so much for your help!
Henry
