Job termination due to version difference on micro level
  • Oct 9, 2019 2:34 PM UTC
  • 99 views
helmoet
Forum|alt.badge.img+8
Hi, We have a workspace that runs fine on our FME Server testing environment yet crashes on our user acceptance environment. It crashes on version incompatibility, like described in the article at https://knowledge.safe.com/articles/363/workspace-fails-on-fme-server-fme-version-incompat.html.
Granted, we use FME Server build 17650/win64/2017.1.1.0 and FME Desktop build 17652/win64/2017.1.1.1. that would be a cause for not running a workspace due to compatibility issues.
However, this baffles me: FME Server version is the same, workspace is the same, what else could cause this behaviour?
I narrowed it down to the workspace below, which is basically a SpatialRelator comparing two box-like area's. Our testing environment runs it just fine, and concludes in the log:
2019-10-09 12:23:30|   0.3|  0.0|INFORM|Loaded module 'SpatialRelationshipFactory' from file 'D:\Prog\FME\FMEServer\Server\fme\plugins/SpatialRelationshipFactory.dll'
2019-10-09 12:23:30|   0.3|  0.0|INFORM|FME API version of module 'SpatialRelationshipFactory' matches current internal version (3.8 20170315)
2019-10-09 12:23:30|   0.3|  0.0|INFORM|Emptying factory pipeline
Our user acceptance environment is however very strict, and for the same workspace it concludes:
2019-10-09 12:00:37|   0.1|  0.0|WARN  |Library 'D:\Prog\FME\FMEServer\Server\fme\plugins/SpatialRelationshipFactory.dll' was found but could not be loaded. Ensure that all the dependent modules exist for this library
2019-10-09 12:00:37|   0.1|  0.0|ERROR |This FME edition does not recognize the `SpatialRelationshipFactory' factory. Please ensure that the current platform supports this factory, the factory name is spelled correctly, and that you have installed all required plug-ins
and terminates the job.
Workspace:
Yeah, true, it's not an AreaOnAreaOverlayer but it is a SpatialRelator, however, using an AreaOnAreaOverlayer does not produce a crash.
Any ideas?
Best answer by mark2atsafe
I searched in our systems and I don't see this DLL fail to load before except in the case where it had been quarantined by a virus scanner. Could that be the case here?! Another reason could be the FME license type. Is it possible that the two systems are using different licenses?
I can't imagine it's a conflict with a DLL from another product with the same name (as has sometimes happened). Do you have multiple FME versions installed on that system?
You could try using a tool like Dependency Walker which might highlight what the issue is, although I tried it on my functioning version and still got warnings, so I don't know how useful it will be.
If nothing here helps, then I would file this as a support case and ask our team to check with the developers.
helmoet
  • Oct 9, 2019 2:39 PM UTC
Oh, forgot to tell, SpatialRelationshipFactory.dll have the same date/version/size etc on both servers.
erik_jan
Forum|alt.badge.img+26
  • Oct 9, 2019 2:55 PM UTC
Nothing about SpatialRelator in the change logs for these versions (2017.1.1.*).
I would send a question to www.safe.com/support
mark2atsafe
Forum|alt.badge.img+59
  • Oct 9, 2019 3:06 PM UTC
mark2atsafe
Also check the properties of spatialrelationshipfactory.dll to see what the permissions and security settings are.
