Issues with reading MVT Tileset ond Writing GeoJSON. When running a Workspace it results to nothing, not sure what the problem is.
  • Jun 29, 2021 11:27 AM UTC
  • 90 views
mikamattila
I have saved MVT tiles locally like this,
c:/3006/0(zoom level)/0(Tilecol)/0(Tilerow).mvt
Skärmavbild 2021-06-29 kl. 13.01.15Information about the tileset below.
<TileMatrixSetLink>
<TileMatrixSet>3006</TileMatrixSet>
</TileMatrixSetLink>
<TileMatrix>
<ows:Identifier>10</ows:Identifier>
<ScaleDenominator>14285.71428571428623399697</ScaleDenominator>
<TopLeftCorner>8500000.000000 -1200000.000000</TopLeftCorner>
<TileWidth>256</TileWidth>
<TileHeight>256</TileHeight>
<MatrixWidth>4096</MatrixWidth>
<MatrixHeight>4096</MatrixHeight>
When I RUN the Workspace I get this translation log (see link) and no GeoJSON file is to be seen. What do I do wrong?
https://docs.google.com/document/d/1u-BgtK6lU4SUKFFPjG-lv4Gs2VYHLc7AIOXo-Is_QB8/edit?usp=sharing
nielsgerrits
Forum|alt.badge.img+67
As far as I can see the workspace did read 0 features and write 0 features.
It's quite hard debugging what it does with a log file only. Can you share your workspace?
From previous questions and answers I think you want to create an offline copy of a basemap, is this correct?
Did you understand what @virtualcitymatt​ tried to explain about the TileMatrix Set?
mikamattila
  • Jul 2, 2021 11:46 AM UTC
Hello,
Updated with Workspace, Zipped MVT files and GetCapabilites Info.
Yes I want to create a local basemap. As I have understood it, MVT files must follow this file structure to be placed correctly (https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/mvt/mvt.htm). I have tried to replicate but with no luck. Not sure what I'm doing wrong.
Thank you for taking your time!
