isPublic="true"
  • July 7, 2014
  • 13 views
fmelizard
Forum|alt.badge.img+22
What does the variable isPublic mean ?
<repository name="Samples" description="" isPublic="true" />
Thank you
mark
  • July 15, 2014
That's a line in the script we use to add sample workspaces to a repository when you install FME Server. isPublic (when true) means the repository is not just available to the user that created the repository but also to other users. Default isPublic permissions are:
// guest - run
// user - read, run
// author - download, read, run, write/publish
// admin - all (download, read, run, write/publish, remove)
I hope this helps to answer your question.
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
