Is there any solution to extract start and end(hour and date) for a workspace execution?
  • Mar 21, 2022 9:13 AM UTC
  • 5 replies
  • 129 views
nicolae.soare
Forum|alt.badge.img+3
hello,
Is there a way of extracting data(maybe from loG) about start and end of workspace execution, as long as errors (if there are any?), in order to insert them in a table?
thx,
Nicu
Best answer by nielsgerrits
Yes you can use the LogMessageStreamer to do this, getting the first and the last features using Samplers.
What I do (using only a Creator, FeatureReaders and FeatureWriters) is adding DateTimeStampers and VariableSetters / VariableRetrievers to the begin and end of the workspace.
The LogMessageStreamer is probably a more elegant solution, but I'm not sure how it influences perfomance in big workspaces.
nielsgerrits
Forum|alt.badge.img+67
  • Mar 21, 2022 10:40 AM UTC
nielsgerrits
Added workspace demonstrating both methods.
nicolae.soare
  • Mar 21, 2022 11:05 AM UTC
Thank you, nielsgerrits !
mark2atsafe
Forum|alt.badge.img+59
For the sake of completion, there are a few other methods.
Firstly you could add a DateTimeStamper at the start and end of the translation. Obviously, it's not quite the same as the exact start/end time, but it could be close enough for your purposes.
Secondly, if you know any Python, you could use a Python startup script and a Python shutdown script to log the datetime. It would be a bit more accurate than the DateTimeStamper.
Finally, a Python shutdown script should also give you the elapsed time of a workspace. That should be fairly straightforward to do, even if you have minimal Python knowledge. I really thought it gave you the start/end time as well, although it's not in the documentation, so perhaps I was wrong.
nicolae.soare
  • Mar 29, 2022 5:36 AM UTC
Thank you Mark!
