Is there an easy way to import a reprojection from the ESPG library
  • May 23, 2023 6:10 AM UTC
  • 34 views
philipwhitten
Forum|alt.badge.img+15
The ESPG library contains some reprojection methods. Is there an easy way to import a reprojection method from the ESPG library? For example, can you copy the text from https://epsg.io/8450 to create a new reprojection method in FME?
daveatsafe
Forum|alt.badge.img+24
  • May 24, 2023 8:56 PM UTC
Hi @philipwhitten​,
FME's Coordinate System documentation illustrates how you can add a new datum transformation to FME, using the parameters from the EPSG description.
