Is there a way to download pictures from twitter using the tweetsearcher?
  • June 13, 2016
  • 27 views
as the title says can you download pictures as jpg or similar that people post on twitter?
dmitribagh
Forum|alt.badge.img+20
Hi @jamiefinney
Yes, it is pretty easy - once TweetSearcher returns the JSON in _tweet_search_result attribute, you can create a new attibute (for example, _image_url) with JSONExtractor with the following syntax:
json["entities"]["media"][*]["media_url_https"]
After this transformer, use ImageFetcher with _image_url, it will return the image.
If you also would like to get aTwitter profile image, use json["user"]["profile_image_url_https"].
I used this technique for our FMECoin contest - see the article here:
http://blog.safe.com/2016/06/fmecoin-whats-behind-...
Dmitri
