Is there a transformer that can be used to upload a shapefile to an SFTP site?
  • May 14, 2014 4:22 PM UTC
  • 39 views
bubblebeb
I have a routine which creates a series of Shapefiles.
The resulting SHP are them uploaded to a SFTP via WinSCP.
Is there a transformer or writter which will upload shapefiles to a SFTP site?
fmelizard
Forum|alt.badge.img+22
  • May 14, 2014 4:56 PM UTC
Never trtied it myself, but the HTTPFileUploader (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/httpfileuploader.htm)would be my first try.
  • May 15, 2014 7:27 AM UTC
you will probably have to implement this in a shutdown script, e.g. using the Python ftplib (https://docs.python.org/2/library/ftplib.html) module and the FTP_TLS class.
Alternatively, consider using the Windows "ftp" command line tool (http://www.nsftools.com/tips/MSFTP.htm), which you can execute from FME in a shutdown script.
David
