Is there a transformer in FME that combines the separate entities (faces of the cube) and make it one solid structure?
  • Mar 9, 2022 3:30 PM UTC
  • 28 views
I have a base shapefile and a 3D model ( but the faces are separate and don't represent a single cube) I want it to combine as a single cube.
Forum|alt.badge.img+54
  • Mar 9, 2022 3:48 PM UTC
If the geometries are already surfaces/faces then you should be able to use a SolidBuilder to create the cube. If they are not faces, you will need a facereplacer first.
