Is there a non-python based solution in FME to convert floats to decimals or vice versa
  • Sep 16, 2020 7:17 PM UTC
  • 45 views
Forum|alt.badge.img+54
I don't actually need a solution, but I'm just curious if there's a way to convert a number from a float to a decimal or vice versa in FME without resorting to python.
So for example reading some data as a decimal, which is then stored elsewhere as a float and you want to do some change detection and consider
56.358400000000003 to equal 56.3584
and
963.299000000000092 to equal 963.299
and
56.358499999999999 to equal 56.3585
  • Sep 16, 2020 7:33 PM UTC
I realised of course that you can also cast to a float in an inlinequerier, or even just change the input type to float. However, both python and the inlinequerier convert the middle example to 963.2990000000001 whilst writing to an oracle table with type FLOAT(126) results in a value of 963.299
I'm working round this by testing the abs difference between the two values but curious to know if there's a better way.
