Is Panchromatic Sharpening possible in FME?
  • Sep 16, 2014 11:23 AM UTC
  • 47 views
I need to perform some panchromatic sharpening operations on some rasters. In Esri I would do this by applying functions to a mosaic dataset.
What is possible with FME? Or am I going to have to use the RasterCalculator and do it myself? If so, has anyone done it before?
Thanks,
Colin
Best answer by conterrastefan
Hi Colin,
If you want to run some functions on your raster, you could give the RasterExpressionEvaluator a try. Hopefully that helps you.
If you want to get full remote control to your FME Server System via your Android mobile phone,
use the new Misson Control for FME Server App from the Goolge Play Store.
It's for free,just search for FME Server and here you go...
Best regards,
Stefan
Hi Colin,
Best regards,
Stefan
