Is it possible to generate a horizontal bar chart with the HTMLReportGenerator?
  • Sep 27, 2022 7:59 AM UTC
  • 85 views
lgrie
Forum|alt.badge.img+8
Best answer by lgrie
hi @lgrie​, unfortunately, no. it can only place bars along the x-axis image--
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
Hello, I did some tests and found out that indeed it is possible.
I used a StringReplacer to replace the word "bar" with "HorizontalBar" in the html code.
That worked for me :)
carmijo
Forum|alt.badge.img+12
  • Sep 29, 2022 1:41 PM UTC
lgrie
  • Sep 30, 2022 1:31 PM UTC
carmijo
  • Sep 30, 2022 2:42 PM UTC
for sure. html has a wide range of possibilities, but it's not something you can do solely with the HTMLReportGenerator. well done
