Is it possible to filter out a single attribute value from data. I am trying to map pit data and although I have streamlined relevant pits using buffer and clipper I still have useless pits which have the same attribute value ie. 2 pits, B pits, and
  • Apr 4, 2022 1:59 AM UTC
  • 5 replies
  • 61 views
Is it possible to filter out a single attribute value from data. I am trying to map pit data and although I have streamlined relevant pits using buffer and clipper I still have useless pits which have the same attribute value ie. 2 pits, B pits, and C pit
caracadrian
Forum|alt.badge.img+23
  • Apr 4, 2022 8:06 AM UTC
You can use DuplicateFilter set to the attribute that needs to be unique.
@david_lyons​ can you include some sample data? Save your workspace using Save As Template... will create an FME template that has the workspace & data
ctredinnick
Forum|alt.badge.img+22
  • Apr 5, 2022 3:08 AM UTC
It sounds like you are trying to remove duplicates in the data, where attributes indicate two pits are identical? The DuplicateFilter works for this (filter out the second+ instance of an attribute value), or the Matcher (identify where two+ features share the same attributes and/or geometry).
HI Mark, so I have clipped down the data down to 260 pits , but there are still some pits on the run that should be out of scope, I would like to remove those pits which are 2pits B and C pits. They are not duplicates but they share the same attribute which is their size.
I just uploaded a sample of the data
