Is it possible to exclude keys already present in a table from a second table before performing translations on that second table?
  • Aug 26, 2020 11:23 AM UTC
  • 87 views
stefanforch
Participant
In my data, I have 3 Oracle tables (numbered for ease of explanation);
1) a spatial table with geometries of tubes used as casings for HV-cables
2) a spatial table with the geometries of the actual HV-cables
3) a non-spatial table with the connection between the tubes and the cables they contain (essentially displaying which key(s) in table 1 is(/are) matched to which key(s) in table 2
What I'm interested in is isolating the tubes which have a cable running through (/on top of) them based on a spatial analysis, but aren't yet connected in table 3. Therefore, I'm looking to exclude all tubes with a key present in table 3 from table 1 before progressing with the other translations (which are going well), but I'm not getting anywhere with Matcher. Is there any other transformer to use here?
Best answer by david_r
One possible solution is to use the FeatureMerger and look at the output from the UnmergedRequestor port. You can do this either before or after doing the spatial matching.
  • Aug 26, 2020 11:31 AM UTC
jdh
Forum|alt.badge.img+41
  • Aug 26, 2020 1:33 PM UTC
Agreed, but I would suspect before the spatial matching would give better performance.
  • Aug 26, 2020 1:58 PM UTC
Agree, in particular if you can get rid of a consequential amount of data this way.
