Invoking a separate workbench from python caller
  • May 26, 2013
  • 60 views
Hi ,
Stuck in a very simple thing it seems . I am trying to call a separate workbench from another by a python caller .Following is the code
#import fmeobjects
import os
# Template Function interface:
def processFeature(feature):
import os
os.system("fme.exe MY-WORKBENCH.fmw")
Entry point : processFeature
Error during translation :
processFeature
2013-05-26 09:26:34|   1.7|  0.0|ERROR |Error executing string `import fmeobjects
import os
import os
os.system("fme.exe MBLB-WORKBENCH.fmw")
2013-05-26 09:26:34|   1.7|  0.0|FATAL |Factory proxy not initialized
2013-05-26 09:26:34|   1.7|  0.0|FATAL |PythonFactory failed to process feature
Please help
  • May 26, 2013
Hi Roy,
wrong indentations caused the errors. See documents about the Python language e.g. The Python Language Reference > 2. Lexical analysis (2.1.8. Indentation).
Why not use the WorkspaceRunner transformer?
Takashi
  • May 27, 2013
Hi Roy,
if, for some reason, you cannot use the WorkspaceRunner transformer, here is an example of using the fmeobjects API from a Python script. I much recommend this rather than using calls to os.sysytem().
David
