Intentionally writing to FME Temp
  • Jul 29, 2014 9:32 AM UTC
  • 118 views
fmelizard
Forum|alt.badge.img+22
Hi folks,
I was wondering, is there a way to intentionally write to FME's temp location?
I want to create a workbench that's portable and needs to write a lot of scratch data using a few workbench-runners (deleted at the end of the process).
Is it possible to intentionally write to it? There doesn't seem to be anything on http://fmepedia.safe.com/articles/FAQ/FME-TEMP-environment-variable .
I've done some testing:
- %FME_TEMP% as the destination just means FME creates a directory called that.
- <FMEDrive> in various guises just results in a workbench crash.
- Not specifying a directory means that FME writes the file to wherever the workbench is saved. Only if it's an unsaved (new) workbench will this be the fme_temp directory itself.
Thoughts? Is this even possible? I'd prefer not to have to hard-code somewhere, or even bother with a user parameter.
Cheers,
Jonathan
Best answer by fmelizard
(Oh, and as a corollary, I'll also need to read from it too!)
fmelizard
  • Jul 29, 2014 9:33 AM UTC
mattwilkie
Forum|alt.badge.img+11
  • Jun 13, 2022 8:32 PM UTC
The transformer for this seems to be TempPathnameCreator.
