InlineQuerier Issue
  • November 6, 2014
  • 86 views
Has anyone noticed when Readers are replaced before an InlineQuerier that the it totally blows the InlineQuerier up? What is the best practice to stop this from happening?
Best answer by gio
Yes, you need to reset the IQ.
Afaikthats is the only thing you can do.
gio
Forum|alt.badge.img+15
  • November 7, 2014
  • November 7, 2014
Does that mean just totally re-do it? If that's the case Safe needs to come up with something better than that. A way to keep it connected when changing out Readers. That's pretty ineffective on Safe's part
gio
  • November 7, 2014
Well not the only one of such.
Try making a complex customtransformer, export it as such.
Then ,like, use more than 1 instance in a workspace, and then decide to go editing it by changing/removing/adding parameters or attributes.....
But still..it is gettting better every new patch and release. :)
