Inesrting existing objectIDs into a relationship class...?
  • June 10, 2013
  • 5 replies
  • 110 views
blueinc
Hi All,
I'm new to FME but not to ESRI and file geodatabase design.
I've set up the file geodatabase with a spatial line feature class, a heirachical table to hold a list of group names and a relationship class to associate the lines with a group record.
I can populate the relationship class in ArcMap (it populates with the OBJECTIDs of the line and the OBJECTIDs of the group record) but I want to do this using FME.
I have seen and followed the tutorial outlining how to add attachments using a relationship class here (http://evangelism.safe.com/fmeevangelist100/) but that example matches the data in a field of the feature class to the filename of the photo and creates new objectIDs using a Counter. I want to be able to force an INSERT into the relationship class using the existing objectIDs of the lines and the groups. How can I accomplish this?.
I'm using Arc10.1 and FME2012.
Thanks in advance for your helpful comments,
B
  • June 11, 2013
blueinc
  • June 11, 2013
Thank you but...that's a link to the same link I had in my comment. That example matches the data in a field of the feature class to the filename of the photo and creates new objectIDs using a Counter. I want to be able to force an INSERT into the relationship class using the existing objectIDs of the lines and the groups.
B
  • June 11, 2013
sorry about that... Given feature class A and B with relationship class R, I would do the following:
  • AttributeRenamer on A.OBJECTID to OBJID_A
  • AttributeRenamer on B.OBJECTID to OBJID_B
  • FeatureMerger on features A and B, using a common attribute (not OBJECTID)
  • In the FeatureMerger, enable Process Duplicate Suppliers
  • Connect the COMPLETE and DUPLICATE_SUPPLIER to an AttributeRenamer
  • Rename OBJID_A and OBJID_B to the foreign keys defined in the relationship class
  • Send to writer
Hopefully this should do the trick.
David
blueinc
  • June 11, 2013
Fantastic solution; thank you! It certainly pointed me in the right direction.
I renamed the OBJECTIDs to their final counterparts and made sure I filtered the groups table down to only one entry so it would do a 1:M join. Then I added the relationship attributes needed to write the records out at the end. Works like a charm! :-)
In this case, the REQUESTOR and the SUPPLIER on the FeatureMerger just happen to share a common field but...what if they didn't? How could I force the join of the two features without a common field, i.e. I want to associate IDs 1,2,3 and 4 in one table with ID 256 of another table...?
I tried using mis-matched fields between them and used the INCOMPLETE output but was not able to get the records out past the transformer.
Thanks again for this!
B
blueinc
  • June 24, 2015
Still wondering about this:
I am now thinking that the only way would be to run the data through a PythonCaller and force the relationship there using code before outputting to the relationship table.
Any thoughts?
TIA
B
