inconsequential regexp treatment in fme?
  • May 13, 2015
  • 42 views
gio
Forum|alt.badge.img+15
I find regexp treatment to be inconsequential?
In stringsearcher this works
This lets "Bomen" pass, but not "BOMEN" or "menBo"
But in NullAttributeValueMapper
This lets "Bomen" pass..but also "BOMEN"
I suspect because of lack of CASE sensitivity control.
(can't use switches in this one).
If i use [^(Bomen)] in the NAM on the other hand it works..and only passes "Bomen".
Why is that? some regexp flavour-mixing?
Best answer by ebygomm
I know different transformers use different regular expression engines, although doesn't specifically mention which category the attributevaluemappers fall into
https://knowledge.safe.com/articles/Error_Unexpected_Behavior/Regular-expressions-that-work-in-one-parameter-fail-in-another
Forum|alt.badge.img+53
  • May 13, 2015
