Importing a GDB relationship from an existing GDB
  • Jan 13, 2023 12:43 AM UTC
  • 110 views
steveflo
Forum|alt.badge.img+7
I'm not sure what I'm doing wrong, but I'm trying to move data from a editing GDB environment to a production GDB. Everything else works fine, except when it comes to importing the relationship class for my attachments. I get the error:
"Unable to create table/feature class/relationship class of type 'geodb_invalid'. Creation of this type is not currently supported by FME, and must be done through Esri tools"
Does this mean I can't import the relationship in FME and should be doing it in ArcGIS Pro?
Thank you.
danminneyatsaf
Forum|alt.badge.img+13
Hi @steveflo​ importing relationship classes from one Geodatabase to another requires a few steps to setup correctly. We have some great articles here on the community that walk through the steps needed to Read and Write relationship classes to a Geodatabase.
If you've already run through these articles, I recommend sharing your workspace and some sample data here so other users here can take a look and comment on what might be causing the workspace to fail.
