IfcWallStandardCase causing reader to crash
  • Feb 15, 2022 9:17 AM UTC
  • 30 views
I have been having trouble with a particular IFC. All I am trying to do is read it in but it keeps causing FME to crash with no expanation.
At first I was trying to open it using FME Data Inspector, however the whole application would close - always at "caching 829 features".
I have since tried to open each Object type separatley in FME Desktop and I have found that it is an element in the IfcWallStandardCase that is causing this problem but the only error I am getting is "Error running translation" so it is difficult to know where to go from here.
Is there any reason why this might be happening?
daveatsafe
Forum|alt.badge.img+24
  • Feb 15, 2022 8:51 PM UTC
Hi @izz88​,
Please create a support case by going to https://community.safe.com/s/submit-case. We will have our developers look at the problem IFC file to try to see why the reader is failing.
