"if": {fme:get-list-attribute("_list{}.IDENTIFICERENDE WAARDE") = "R"} , "then": {"amount" : @Value(_list{1}.BDRG_NETTO)} If i use this in jason templater it yields following "if" : true, "then" : { "amount" : 10000 }
  • Apr 28, 2022 2:35 PM UTC
  • 102 views
gio
Forum|alt.badge.img+15
Which i then replace with regexp.
How can i have it just yield following result?
 "amount" : 10000
I'd like to have it solved inthe Templater rather then resorting to regexp clean-up.
Tx in advance to all.
Best answer by debbiatsafe
Hello @gio​
As the if then keywords are quoted, they are added to the JSON output.
Try the following XQuery expression in the JSONTemplater to get the desired output.
{if(fme:get-list-attribute("_list{}.IDENTIFICERENDE WAARDE") = "R")
then {"Value": @Value(_list{1}.BDRG_NETTO)}
else {}}
I hope this information helps.
debbiatsafe
Forum|alt.badge.img+24
  • Apr 28, 2022 9:53 PM UTC
Hello @gio​
else {}}
gio
  • Apr 29, 2022 7:41 AM UTC
Hi Debbie
Yes it helped.
Also i found out, after i asked the question that my snippet is javascript en not jason script.
Indeed i needed to take the if then out of the json part.
I have it like this now and it does it's job.
Ill SaS your answer.
"amount":
  {  if(fme:get-list-attribute("_list{}.IDENTIFICERENDE WAARDE") = "R")
    then { @Value(_list{1}.BDRG_NETTO)}
    else {}}
tx for help.!
