I want to filter a date attribute field. I only want the features with the current date to return. What would be the way to go?
I would use AttributeCreator using the Text Editor function in the properties of that transformer. There is an option called DateTime Functions and then DateTimeNow. Use a DateFormatter transformer to format to the desired date type and then a Tester to see if your date matches the new attribute.
Maybe quicker ways but that is how I would do it
erik_jan
Forum|alt.badge.img+26
  • May 4, 2017
I would use the Tester if you have FME 2017. You can use the Arithmetic Editor to do a formula like:
Current_day - Date_attribute in days < 1 (not always today, but less than a day old).
or Current_day (formatted as "YYYYMMDD") = Today() (formatted as "YYYYMMDD")
  • May 5, 2017
Thanks for the answers. I'll give it a shot!
